  • 7 Vote(s) - 3.71 Average
First problem since october 2010
Having owned my Berlingo since last October, i might add without any problems until this afternoon.
So on our travels i had the noise of two beeps and the water temperture gauge needle was over the top, and at the bottom in red it sed stop.
Has anyone else had this happen, if so what is the problem, should i be worring has it happened twice.:whistle:
Had it on mine, it was the water temperature sender in the engine block.
It would come on, then go off after about 2 minutes, did this a few times, so I thought I'd replace it, took it out just for a nosey to see how hard it would be to replace ( very easy ) put it back in and it's been fine ever since!!
That was 2 years ago!
Has your radiator fan packed in?
Will have a look at that then, same engine as mine but mine is a 53 forte, thanks for the reply Steve..
Thanks Andre i will check that as well, but i think Steves hit the nail on the head as i had only just set off, and the water temp hadn't even got warm..
(02-04-2011, 08:13 PM)gary Wrote:  Will have a look at that then, same engine as mine but mine is a 53 forte, thanks for the reply Steve..
Yeh you're right, i didnt read it properly. Let us know how you get on
(02-04-2011, 08:13 PM)gary Wrote:  i had only just set off, and the water temp hadn't even got warm..
Same as what mine used to do, just took it out, looked at it, put it back, fixed!! like magic!! Big Grin
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
