  • 7 Vote(s) - 2.86 Average
Wheel bolts
Hi everyone.
Quick question about wheel bolts.
I have just fitted Peugeot 205 alloy wheels to me Mk2 Van. The alloys seem to be thicker than the steelies and therefore the bolts do not screw in as far with the alloys as they do with the steelies. Is this a problem or will it be ok as long as the bolts have enough thread to tighten and there is no movement or gap?
Cheers, Murdo.
Get longer bolts!
I have spacers on my van & alloys. The answer is indeed longer bolts.
Try the nuts & bolts shop in Roachford Essex. They are on eBay & they are very good. Used them on numerous occasions. Good luck .
Make sure you use the type for alloy wheels -square shouldered.
A vehicle that had steels fitted at the factory will usually have tapered shoulder bolts.
I'd hazard a guess thats why you're finding your original ones 'too short' because the wrong profile of the holes are holding them off?
  • RolyG
mmh okie dokie.
Emailed an alloy wheel company and they said to "make do" with origional bolts as ones to fit 205 alloys to berlingo would most likely need to be custom made!?!?!?! :O
(02-04-2013, 10:37 PM)murdo2520 Wrote:  mmh okie dokie.
That sounds well dodgy!
BS.
I think you were talking with the tea boy.
You could end up stripping the threads in the hubs if the bolts don't go in far enough.
If you've got the tapered shoulder bolts they could fracture the holes if you really tighten them when trying to get at more thread.
The only fitment differences could be the centre bore size and the offset.
However in this case Carl Salter says the bore is the same
But just check;
Do your alloys all seat nice and flat on the hubs without forcing them on?
Yes is the right answer.
Is there any up/down movement when they're on there without the bolts
No is the right answer
The offset is just worth a quick look but its mostly fairy stories around MK2s not accepting Slightly wider wheels.
If the wheels are standard Peugeot 205 then standard '205 alloy wheel bolts will fit them to your van perfectly.
New bolts are best but ebay will yeild 16 used ones for much less.
But do bear in mind if you fit ANY used bolts to your car it will flip over into a fireball and the Book of Revelation will come true and your insurance will be invalid.
And your wheels will fall off
And your willy:whistle:
  • murdo2520
And the number of the beast shall be 165-75-R14.
:lol:
(03-04-2013, 12:23 AM)addo Wrote:  And the number of the beast shall be 165-75-R14.
So what length bolts did you go for, or you still chancing the original ones. m in the exact same pickle..???? Confusedcratch:
Do NOT even think about driving with wheel bolts that may be too short!
Take a look here. You can see which kind of bolt you need to order.
http://www.performancealloys.com/wheel-n...bolts.aspx
Don't be tempted to buy the cheapest available....the suppliers don't mind if
you damage your car when a wheel comes adrift!!
  • addo
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
