  • 23 Vote(s) - 3.26 Average
Long gear selector lever
Wife has a 04 multispace. The connection between gearstick and "long gear selector lever" has somehow snapped. After two weeks local dealer still does not have the replacement part and cannot give a date as to when he can get it. Can anyone help? It's the BE3/5 - BE4/5 type transmission. Thanks in anticipation.
Hi, Solo.
Send VIN to PM and i'll tell you model of gearbox and what sparepart you need
[-] The following 1 user says Thank You to pk7478 for this post:
  • solo
Have you tried a Peugeot main dealer ???. Will need the V.I.N. number and they can cross-reference parts vis-a-vis with the equivalent Citroen.
Worth a try if you are stuck.
Never tried the local Pug dealer. I figured that they would be using the same source as Citroen dealer and would struggle to obtain part also. Might give it a go.
Annoying thing is, that it would be so easy to repair if I could get the darn thing off myself but no way to get the car up high enough.
pk7478, have sent you VIN no.
Solo.
You have BE4-5L MANUAL GEARBOX
Peugeot and Citroen uses one part number- 2414 H3 SELECTION ROD.
pk7478. Thanks for that. Will go on the hunt tomorrow.
In the meantime if anyone has one lying around???????
Found a new one here if you are still looking?
Chris.
This is spare part 2414 F2
Ah, missed that small detail Confusedillyme:
Thanks for pointing it out
Today 09:56 PM
Yesterday 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
Last Post: stu76
18-08-2026 07:16 PM
