  • 30 Vote(s) - 3.27 Average
'03 plate Berlingo Multispace Forte steering wobble..??!
I have the following issue...
It's not really something that worries me however it gets a little annoying on curvy roads..
basically the car is a great drive however in corners it feels sometimes as if it wants to pull the steering wheel straight.
It can't be serious as I have done plenty of miles like this it's just getting on my nerves lol
anyone know what it is or what causes it?
Could be the tracking geometry is out, but it is worth having a look at the coil spring as these are a known weak spot and can break. Are the tyres wearing unevenly? My suggestion would be to get your local tyre centre or garage to have it looked at to be on the safe side.
(05-04-2011, 09:56 AM)Chris Wrote:  Could be the tracking geometry is out, but it is worth having a look at the coil spring as these are a known weak spot and can break. Are the tyres wearing unevenly? My suggestion would be to get your local tyre centre or garage to have it looked at to be on the safe side.
ohhhh crap I will have a look in a bit see if I can check the springs.
If not I will go the tire place and ask them.. thanks mate
can it not have something to do with the steering rack?
Although its a weird problem for that...
It just feels like it wants to steer back on you in little shunts..
** 2003 CITROEN BERLINGO M-SPACE FORTE D SILVER 1.9D...... :woop:
** 1999 Peugeot 306 2ltr HDi Turbo sadly breaking...... :ill:
** 1992 Toyota Land Cruiser, 4.2 Ltr. Turbo Diesel off-road monster......
** 1970's Honda CB750 Four Custom Chopper......
Whatever the problem is, something isn't right, so makes sense to get it checked out.
[-] The following 1 user says Thank You to Chris for this post:
  • TobyJug
(05-04-2011, 10:30 AM)Chris Wrote:  Whatever the problem is, something isn't right, so makes sense to get it checked out.
true lol...
I just have not had the time yet...
Will try and swing by the garage after and see what they say..
dankje..
Toby. I have the same pull you have and with mine it wears the outside of my tyres (just replaced), I need to get the tracking done as mine is out, it's getting the time that is my biggest problem
Lliam
70 plate Berlingo
(05-04-2011, 07:00 PM)lemsworld Wrote:  Toby. I have the same pull you have and with mine it wears the outside of my tyres (just replaced), I need to get the tracking done as mine is out, it's getting the time that is my biggest problem
Oh I am so glad to hear I am not the only one...
yeh I have had a look today and the tires wear the same way as yours..
I looked at the springs etc.. and all seems well..
I will try and find time to go and get the tracking done... hopefully that should sort it then... thanks mate...
It took about 6 months maybe less for the edges to wear completely before I knew so will get it done as soon as I can. I was given the price of £12.50 for the tracking
Lliam
70 plate Berlingo
[-] The following 1 user says Thank You to lemsworld for this post:
  • TobyJug
(05-04-2011, 08:44 PM)lemsworld Wrote:  It took about 6 months maybe less for the edges to wear completely before I knew so will get it done as soon as I can. I was given the price of £12.50 for the tracking
I see...
Yeh I can see the wear on my tires so I will go and get it done asap..
(when I find the time that is...)
thanks again....
Hiya TobyJug, if I go around a long corner, the steering wheel sort of gives little nudges almost as though the car is under load/not under load/under load briefly. Haven't had a look at the tyre wear though, maybe I'd better. Dave
2005 Multispace 1.9D poseidon blue
Yesterday 09:14 PM
Yesterday 07:10 PM
» Replies: 19
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
