  • 19 Vote(s) - 2.58 Average
1.6 Hdi 92: least revs without labouring engine
I'm still getting used to driving a diesel, and in particular the 1.6 HDi 92 engine in my Mk 2 Berlingo.
What surprises me is how highly the vehicle is geared. It seems to me that it really needs to be up to about 45 mph to get into 5th - or, to put it another way, the minimum number of revs for driving in 5th is about 1500. But then I don't really know much about driving a diesel.
Those of you who drive the 1.6 HDi 92 - what is the fewest revs you can drive at in 5th gear without labouring the engine?
(I don't know if the answer depends on whether one drives a Mk2 or Mk3 Berlingo.)
id say 1500 is the least you should go, and change up at 2500 - 3000
I can go into 5th at 30mph dont have to use much diesel then. Is this a bad thing then?
Lliam
70 plate Berlingo
I believe you are right!
We had an astra 1.9cdti courtesy van (very fast and very comfortable may i say!) and it had 6 gears, and we found our fuel economy improved quite significantly compared to the berlingo (sitting in 6th at 70mph)
When we asked the dealer why the berl didnt have the same 6 gears (even as an option), he said it was because the van was geared higher anyway.
(06-04-2011, 09:19 PM)Northman Wrote:  I'm still getting used to driving a diesel, and in particular the 1.6 HDi 92 engine in my Mk 2 Berlingo.
On the level 1200 RPM is OK.It will drive without labouring 40 MPH on gentle inclines,& 50 mph up a wall.For hard acceleration I drop to 4th(not very often).'57 1.6 HDI 92.
I rarely go over 2500 through the box or sat in 5th.
The lag at about 1900 (30mph in 3rd) is a pita.
YB :wave:
(27-05-2011, 08:49 PM)Yorkshire Bling Wrote:  I rarely go over 2500 through the box or sat in 5th.
YB :wave:
Is that a 2.0 HDI thing?My 1.6 HDI has no lag problems at all under any throttle conditions.
Yet another ABS fault
Today 10:56 AM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
