  • 7 Vote(s) - 2.14 Average
starter relay issue
hi can anyone advise where the temp sensor is (starting relay related)
and also where the ic0a2 (i think) is located ie ive read the wiring to the starter relay box can go faulty! a photo of the above area would be greatly appreciated!!
Which engine?
dw8 1.9 non turbo (99reg)
Have a read of this. Confusedalut:
http://www.berlingoforum.co.uk/showthread.php?tid=1875
i read this post but cant find where that connector is that may be the fault. is it under the battery or in the fuse box in engine bay( black cover)
If I can remember, its somewhere on the front cross member near the radiator, nearside.
[Image: e3u48.png]
this post is mark 1 berlingos,not hdi
I think your getting confused Tenerife123 that is the diagram you need the text under the picture is just Rustscrat signiture.
  • Rustscrat
ahh ok, my apologies thank you
is the componet a round black thing with lots of wires going into it?
Yes there should be two of them, think it's the larger one you want.Confusedalut:
Last Post: gitt
Yesterday 08:27 PM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
2011 B9 DPF warning light
22-01-2025 10:51 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
21-01-2025 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
21-01-2025 12:43 AM
