Threads: 67
Thanks Given: 1,045
I've no idea who worked on the car, I know many service parts were bought by the last owner and fitted by another party.
At a guess I'd say the caliper has strained the hose. Most age-driven flex hose failures are internal from my experience; this suggests external stressors.
The rears were due already on my standard basis of being 12 or more years old, I'll now be in for a full set - the only question is Goodridge or HEL...
Threads: 67
Thanks Given: 1,045
05-04-2013, 12:20 AM (This post was last modified: 05-04-2013, 12:20 AM by addo.)
Good to have some experienced input. Leaning towards HEL at present; 69 squid plus a tenner for post. That total would only buy me two Sasic front flexes locally.
I like the clear coated lines - not for showiness but because they expose any weeping under the PVC cover.
Threads: 67
Thanks Given: 1,045
Threads: 67
Thanks Given: 1,045
Threads: 67
Thanks Given: 1,045
To be perfectly honest, I am a little underwhelmed. There are no overmoulds on the lines; no grommets to locate in the strut holders, no anti-chafe wire coils. A faint smell of hydraulic oil (presumably from the crimping machine) and signs of light buffing to the crimped ends. The biggest disappointment is the "cogged" female ends of an OEM spec line, are not replicated.
Anyway, they'll do - but another time I would simply return to the Goodridge supplier I've previously spent a bit with.
Threads: 67
Thanks Given: 1,045
01-11-2013, 09:27 AM (This post was last modified: 01-11-2013, 09:28 AM by addo.)
"Pictures, or it didn't happen"
I sliced off the old front hose overmoulds, and recycled them along with the protective springs. The rubber grommets can be slit with a razor blade, cleaned with brake cleaner and then superglued shut again.
To the rear you can also see my preventive bead of sealant around the outboard shaft bearing, and copper grease aplenty.
