  • 4 Vote(s) - 3.25 Average
CLUTCH
Hello.
My clutch has just gone today on my Multispace 1.6 diesel 2011 model.
Any one know the best place to order from? and a rough idea of price?
Any info on this will be greatly appreciated.
Thanks Kevin
If the failure is premature it could be a warranty issue, particularly if dmf has failed unless you have done exceptionally high mileage. GSF prices here
(05-04-2013, 08:42 PM)Opensauce Wrote:  If the failure is premature it could be a warranty issue, particularly if dmf has failed unless you have done exceptionally high mileage. GSF prices here
Thanks for reply.
Milage is 86000, it is a Taxi so warranty out.
Did not show any signs of going, Just went, when it is started up you can feel it juddering, cant get any gears, wont even move if started in gear.
Hope it is not the flywheel too???
Thanks Again.
EuroCarParts got their usual sale on as always.
Thanks Again.
How will I know if the flywheel has gone too????
Is it not a solid flywheel on your model ?
(05-04-2013, 10:16 PM)taxi Wrote:  Is it not a solid flywheel on your model ?
Not sure it is a 2011 Citroen Multispace 1.6 HDI 90 VTR Diesel.
Any Ideas from that????
It appears that at least until RPO 12074 they were DMF type (P/N 0532.Q4). After that it's not clear from the part description (0532.T2).
The later clutches are serviced as a kit only - you get the cover, friction disc and release bearing under one call number (also sold as a factory refurbed set).
Taxi drivers will often fit solid clutches in place of dmf, solid kits are available for Mondeo & Skoda, don't know about Berlingo. The GSF clutch kit £616 is dmf.
I have 2011 airdream, solid clutch, and ads state the manual models have them ,also.
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
