Threads: 2
Thanks Received: 1 in 1 posts
Hi since I bought my Berlingo I have the same problem. It takes at least 5-6 miles for the temperature to start rising. It never reaches 90 degrees. Its usually between 70-85. Eventually you can feel that the heating is working but not for long. After a while it's starting to blow with cold air and the temperature is rising to 85. Then suddenly it starts blowing with warm air again and the temperature drops to 75. So lets say 5 minutes of warm air then 2 minutes and again 5 mins warm , 2 mins cold .....and so on. After 200-300 miles coolant level drops and its the engine starts to slightly overheat. When its blowing with cold air temperature rises up to 100. So my car mechanic replaced the water pump and the thermostat and it didn't help. I'm going to flush the system with some cleaning liquid today and I'll check if that would make any difference. Can anyone help me with that problem? The van only has 40000 miles on the clock. Its very weird that the coolant level drops tho.
Threads: 9
Thanks Given: 316
15
Ideally you need to get it pressure tested because you are losing water some place.
When I first started reading your post I thought air lock but as the post went on im starting to think head gasket but at 40k that's very odd unless its been very hot at some time? If its been very hot it could be the gasket but also a crack in the head, block would produce the same fault.
I suspect its a leak in the cooling system some place but you may also have an air lock - like I say you need it pressure testing by someone who knows what they are doing.
Threads: 2
06-04-2013, 12:43 PM
(This post was last modified: 06-04-2013, 12:44 PM by grawcu.)
thanks I was thinking about a leak somewhere.The head seems ok cause there's no sign of the water(bubbles) in the oil
