06-04-2013, 08:22 PM
Hi
First post on this forum so please be gentle!
Friend of mine has a 2005 Berlingo 2.0 HDi. Her alternator failed so a mate and I replaced it with a new 150amp unit.
2 days later her engine management light popped up on the dash and the engine went into 'limp home' mode. My OBD reader would not connect to the Berlingo computer so it went to a local garage to be read.
The codes it came back with were:
P1352 - Glow Relay - Short circuit or defective
P0113 - IAT sensor - open cicruit/positive short
P0102 - Air mass-meter signal - open circuit/earth short
Putting aside the glow relay as the cause (as I believe this would not cause a limp-home problem) I concentrated on the other 2 codes. Finding the IAT and MAF were integrated into one unit I tested the 5 wires at the plug and got what I believe to be the correct readings - 5v/12v/earth/0v/0v. This lead myself and a mate (who is an electronics tech for the RAF) to concluded that the MAF/IAT was faulty and ordered a new one.
The new unit arrived and was fitted. Starting the car, the dash beeped and the 'Check Engine' light went out. Left it idling for 5 minutes then took it for a test drive. 5 minutes into the test drive the dash beeped, the light came on and the engine went into limp mode. 10 seconds later, another beep, the light goes out and full power is restored. 30 seconds later, beep - light - limp mode.
I then removed a known working MAF/IAT from a Peugeot Partner and put it in the Berlingo. The light would not go out. As a double check I then put the Berlingo MAF into the Partner and it drives all ok - no light.
Therefore, if the new MAF/IAT is ok, all the voltages/earths at the plug are ok and the air filter, air box and rubber hose from the airbox are all ok what on earth is the issue. I am out of ideas and would appreciate any help/ideas.
Ta
Ade
Ta
Ade
