Thanks Given: 2
I set off and about 5 seconds later the engine died. I thought i'd stalled at first but when i tried starting up again she turned over but would fire up. Anti pollution came up on the display. It keeps turning over but wont start. The 'anti pollution' diplay doesnt come on now.
Any ideas folks?
Threads: 67
Thanks Given: 1,045
Hi, it would help to begin with a quick summary of engine/year.
Threads: 16
Thanks Given: 46
5
Possibly egr valve failure. Its what happened on mine. Anti polution fault came up on way home & car went into 'limp mode' 35mph. Car would not start next morning, AA tow to Citroen garage & new egr valve £520 bill. Egr valve had failed, part dropped out of it when they removed it. Car was under 4yrs old but out of warranty of course. A few emails to Citroen UK giving them my thoughts/opinions & I recieved a £300 cheque for cost of parts so final bill was £220.
Citroen parts charge £300 for Valeo egr valves but you can find Valeo egr valves for 1.6diesel from ebay suppliers for under £100 & other suppliers for £160 so make of that what you will. You can also get egr blanking plates for 1.6 diesel off ebay but probably not a good idea with modern cars.
Threads: 16
Thanks Given: 46
5
08-04-2013, 05:55 PM
(This post was last modified: 08-04-2013, 05:56 PM by Opensauce.)
All sorts of opinions on this on the internet, some reckon if you blank off a current car, engine light stays on & need ecu sorting to turn it off. Some say exhaust temp is raised, shortening life of turbo. Emissions is not tested on diesels for mot only smoke. There is talk that soon mot tests will incluce diagnostic check to detect if anti polution devices have been blanked/removed....make of it what you will....
Threads: 50
Thanks Given: 743
10-04-2013, 11:38 PM
(This post was last modified: 10-04-2013, 11:40 PM by Ol'Jeffers.)
Well, firstly, any PAS tech with a reasonable amount of savvy would be able to see if the
EGR valve was removed so no need for diagnostics. Same goes for DPF (FAP) and CAT.
If my EGR valve needs replacing I'll remove it and use a blanking plate. If, in the
future, legislation states that my car must have one then that's the time when I shall fit it.
The great news is that my car has no DPF (OEM) so there's one potential problem I won't have to deal with.
