  • 3 Vote(s) - 4 Average
[Transmission] Engine/Gearbox Juddering
[/size][/font][font=Courier][size=medium]Hi guys, Im experiencing a pretty bad shuddering going on in my Berlingo '98' 600D van... Going up through the gears, If i keep my hand on the gearstick It kinda rocks in what i can desceribe as an eggshape motion, seems to be speed related and then when out on the road when im going uphill or when the engine starts to struggle it judders like mad, engine gearbox the lot, Im not getting any slip on the clutch, the bite is still exactly the same as its been since ive had it and no obvious oil leaks around it. Im just wondering if anyone has encountered the same symptoms or has an idea of what could be causing me this issue. Thanks MG.
Attached Files Thumbnail(s)
Engine mountings?
Thanks Ron, whats the best way to test the mounts ?? Ive tried just grabbing hold of it and giving it a good ol shake, couldnt really move it tbh, Id like to think that it is just the mounts .........
Check the mountings visually,look for signs of cracking,bonding breaking.The L/H (trans) mtg seems to go first.
Non start after battery disconected.
Today 05:42 AM
Battery State of Charge unit wiring
Last Post: Limbs
Yesterday 09:40 PM
Headlight replacement b9
Last Post: shawstvs1
Yesterday 04:22 PM
Rear Light cluster wiring fault
Last Post: Jed Clampit
15-02-2025 11:04 PM
App change and engine oil
Last Post: Galagemm
15-02-2025 06:22 PM
oil Sump
15-02-2025 05:37 PM
Fitting a reverse camera
Last Post: jboy012000
15-02-2025 12:20 PM
Android aftermarket headunit question
Last Post: ae3
15-02-2025 10:27 AM
Cant deactivate the ESP
14-02-2025 07:01 PM
Rear brake caliper piston problem
14-02-2025 07:37 AM
