Threads: 12
Thanks Received: 4 in 4 posts
Thanks Given: 1
09-04-2013, 08:17 PM
(This post was last modified: 10-04-2013, 08:13 AM by Andre.)
Site Problem Error - Now won't let me delete??
The tyre pressure/type info plate is missing on my 2009 1.6HDi (90BHP) XTR
Does anyone have a pic of this plate with the info on for my model/year
Thanks in anticipation
Threads: 84
Thanks Received: 399 in 341 posts
Thanks Given: 179
22
2.3 bar all round and 2.6 in the back if you have to carry lots of bodies....
Threads: 147
Thanks Given: 263
11
Can i ask what the issue was with the site? Duplicate posts have happened several times over the past few days. Was it slow to load and you pressed Post Thread multiple times?
Threads: 84
Thanks Given: 179
22
(10-04-2013, 08:32 PM)ouradventure Wrote: (10-04-2013, 08:15 AM)Andre Wrote: Can i ask what the issue was with the site? Duplicate posts have happened several times over the past few days. Was it slow to load and you pressed Post Thread multiple times?
I had just replied/edited a previous post OK, then on creating a new post. When I came to click the 'post' dialog button received an error message I think began 'e45'
However the other two dialog buttons adjacent responded correctly.
I pressed the dialog button 4 times and although it didn't appear to post correctly (e45 error message) on checking later I found I had posted 4 times.
On trying to delete the whole post via the delete function left tick and right hand confirm the program error messaged again and stopped.
I hope this rather incomplete description helps you to debug.
Alsoknowing the Os and browser version number may help as not everyone is having problems
Threads: 6
Thanks Received: 3 in 3 posts
Thanks Given: 2
I have the same model and year as 'ouradventure' and the plate on mine does not agree with the one pictured for the normal load figures. Although it seems illogical it indicates 2.4 for the front and 2.3 for the rear for normal load.
By the way, I had several attempts to get a reply through as hitting the reply button came up with a window telling me I had no Broadband. Eventually won after two attempts with the 'new reply' button.
Threads: 84
Thanks Given: 179
22
(13-04-2013, 02:08 PM)GJT Wrote: I have the same model and year as 'ouradventure' and the plate on mine does not agree with the one pictured for the normal load figures. Although it seems illogical it indicates 2.4 for the front and 2.3 for the rear for normal load.
Tyre sizes vary on different spec vehicles -Mine are the chiunky 195 65 15 van issue
