  • 4 Vote(s) - 2.5 Average
Interesting Lexia Result
Xsara II arrived at another workshop on the end of a rope. I was called to attend with my Lexia, as the indie there doesn't do electronics very well. 2.0 petrol twin cam with autobox.
Symptoms: No start/run, one blink only on the noid light.
Checked: BSM by substitution, all the usual (plugs, fuel, timing belt), fitted new battery.
Global scan, all good. Said no fault in the engine ECU but wouldn't let me access the fault log ("communication error") - I could view all other aspects of the ECU as normal.
On a hunch, I "cleared" the fault log, even though it was saying no faults found. Punched in the current mileage and everything in the delete process went normally.
Now I could read the fault log - no faults found.
Then it started! :eek: I read the running parameters and it had a blown coil on 2/4. New coil and all was good again.
I'm wondering if somehow the dead coil had "jammed" the ECU, as although it stated it was unlocked, it was saying the fuel supply relay was inactive. Perhaps it was expecting the other half of a waveform, which never arrived.
And on a totally, totally, random note I am so going to book tickets for Daft Punk's album launch, which is happening at the agricultural show in a fair dinkum outback town. $35 apiece is too good to miss, even with $160 in return petrol costs...
Thanks for the info.... a good read too.
Very interesting,if only I understood all of it.
Some of us older mechs don't fully understand modern electrickery.
I find finding/identifying sensors hurts my head a bit.Confusedalut:Confusedalut:Confusedcratch:
  • andy-womble
(11-04-2013, 07:10 PM)ron Wrote:  Very interesting,if only I understood all of it.
Anyone know how to carry out "spill timing" on a 2.0HDI ????
Think I may have a 'Communication' problem with my missus,
Can i use a Lexia to find out whats wrong with her and if so where would I plug it for best results?
Any suggestion will be forwarded to her for retaliation later
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
[/quote]
Those were the days of the Hartridge testers & rebuildable injectors.
You've made me sob.:drool:
(11-04-2013, 07:24 PM)terryd999 Wrote:  Think I may have a 'Communication' problem with my missus,
I don't have a coms problem,I don't talk to her.:whistle::whistle:
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
