  • 2 Vote(s) - 3.5 Average
under engine cover
hi ive just got home and noticed that my plastic under engine cover is hanging down. the front is fixed ok on both sides of the front.from what i can rember when i done the oil change. is it 2 bolts one each side of the front and 2 plastic push in studs on either side. can anyone comfirm this for me. many thanks lads.
sorry its a 2004 2.0 hdi multispace.
On mine there is a centre dzus and then 2 studs with 6mm nuts one each side of the dzus fastner then on each side it attaches to the inner wing liners with a 90 degree hand turn fixing that pushes up and fixes the panels together. Then there is 1 stud fixing in the middle that has a 6mm nut on, as you push it on from the front it locates on to the rear subframe and then the nut holds it in place.
ok tomcat thanks for the replie, ill try to get some new hand turn fixing to morrow. i could take the cover off but would prefer it as its ment to be.
This is what the fixings look like. http://www.ebay.co.uk/itm/citroen-unders...4853592323
On our 2010 XTR you can drain the oil without removing the undertray.
Peter
that would be handy
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
