Threads: 50
Thanks Given: 743
Have you checked the aerial is still connected and working? There is a likelihood
that moisture has got in and corroded the connections or that the plug has simply vibrated loose.
If that is the case a new radio won't cure the problem.
Thanks Given: 188
23
Im sure ive read on the forum that radio units are coded to the vehicle so you may have to get it decoded or sort it with lexxia software first but dont quote me on that. Some of the tech guys may have the answer for that and as Ol`jeffers says check the aerial mount in the roof first it could have water damage and poor earth.
Are we there yet?????
Threads: 39
Thanks Given: 1
4
If the radio is faulty just buy an aftermarket one and the correct connecting lead as you won't need to bother about coding and according to my friendly Citroen Dealer the stereos are pants and aftermarket ones are better value.
We did this with our mk1 and it was fine. The only problem for you will be that it would not look as good in the curved dash.
Peter
Threads: 12
Thanks Received: 8 in 5 posts
Thanks Given: 5
Thanks for all the replies gents.
Jeffers,I dont think the aerial is the problem.Water was entering through the aerial base,I took all the contacts apart and sprayed them even though they looked OK,with still no ball.I put in another stereo that I had fitted to my old Pug Partner and it works perfect,but I would perfer that the proper unit for my model is fitted so I can still have use of the dash display and stalk controls.
Threads: 20
Thanks Received: 3 in 3 posts
Thanks Given: 14
I've got one for sale if you're interested?
