  • 3 Vote(s) - 3 Average
Using 5th gear
Hello all,
Just wondering what sort of speeds you are reaching before engaging 5th gear. I usually only put it in 5th when the speed is 40mph ish. I have a 1.9 DW8B Multispace year 2000 X plate.
Read somewhere that if you use 5th at too low a speed it will wear the gearbox quicker. What are your views? Many thanks, Dave.
Smile it's already happened! Big Grin
On the level I can drive in 5th @ 30mph. Generally 40mph is good on gentle climbs only.
At the end of the day I use the gear the old girl feels happiest at.:thumbsup:Confusedalut:
[-] The following 2 users say Thank You to ron for this post:
  • RolyG, trader97
I have 2.0 hdi and sometimes mine used to struggle coping in 4th doing 30mph as it was too slow. I bought a tuning box a couple of days ago and am still experimenting with the different maps as settings but now I can do 25mph in 4th and even 30mph in 5th. I'm hoping this will maybe improve mpg even though I'm happy with existing mpg
[-] The following 1 user says Thank You to C4LL_D for this post:
  • trader97
at 35mp in town i use 5th. if i need to accelerate i go into 4th to 50-55mph then go to 5th. 5th is useless at accelerating.
[-] The following 1 user says Thank You to inzor for this post:
  • trader97
Whatever speed feels comfortable depending on conditions. there is no hard and fast rule.
[-] The following 1 user says Thank You to Romahomepete for this post:
  • trader97
(19-04-2013, 09:07 PM)ron Wrote:  On the level I can drive in 5th @ 30mph. Generally 40mph is good on gentle climbs only.
Same here, drive in the highest gear it wont struggle with, save petrol.
[-] The following 1 user says Thank You to talos for this post:
  • trader97
If your centre display will give a real-time MPG figure use that to guage .If the motor is labouring the mpg will drop
[-] The following 2 users say Thank You to evdama for this post:
  • addo, trader97
That's exactly my take on it - sometimes the results surprise, and you actually start to appreciate why a modern autobox may be shifting like it does.
  • trader97
I have read many places that state 'change into the highest gear as quick as possible'.
Very bad advice. An engine that is labouring will use more fuel.
In general:
30mph = 3rd
The correct gear gives you more control and allows the engine to run more economically.
[-] The following 1 user says Thank You to MudFT for this post:
  • trader97
(20-04-2013, 06:41 PM)MudFT Wrote:  I have read many places that state 'change into the highest gear as quick as possible'.
In general:
30mph = 3rd
MK2 HDi. I find if its a 30mph zone, stay in 3rd. If you try and speed, engine sounds like it it is over reving. It helps to stay in the legal zone.
[-] The following 1 user says Thank You to Modmytop for this post:
  • trader97
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
