Thanks Received: 2 in 2 posts
Thanks Given: 5
eHDi XTR 2013
Do Citroen actually sell (or are after market available)? I have spent significant time on EBay with no luck.
Does anybody have the manufacturer specific positioning and shape specn?
Whilst historically I always 'Black tape' and line up against a vertical wall ! am somewhat nervous about long term degradation of the polycarbonate headlamp covers.
I use the car regularly abroad so leave the patches on permanently.
It is NOT good enough to just wind down the headlamps - significantly reduced illuminated area. The kickup to the left is also very pronounced.
Threads: 13
Thanks Received: 44 in 29 posts
Thanks Given: 29
21-04-2013, 07:55 AM
(This post was last modified: 21-04-2013, 07:57 AM by MarkT.)
Hi there,
This thread may be of interest:
http://www.berlingoforum.co.uk/showthread.php?tid=1513
There's a letter from citroen on post #11 which says they're not needed on this model of headlight. I didn't bother using deflectors on my recent visist to France and had no problems (I was actually randomly stopped by the police and they didn't have an issue with lack of deflectors). I did take a copy of the letter but didn't need to show it.
Mark
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
The following 1 user says Thank You to MarkT for this post:1 user says Thank You to MarkT for this post
• pmh
Threads: 5
Thanks Received: 30 in 22 posts
Thanks Given: 1
As far as I was aware they are not required.
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
"The kickup to the left is also very pronounced."
On my Octavia there is a lever in the h/light that can be moved to produce a flat beam with no kickup. I wonder if the berlingos have the same?
:eek:
Threads: 16
Thanks Given: 46
5
The lights on UK Berlingos are definately 'rhd' as signified by the arrows on labels. There are small points of light that go to left but I assume these must be at ground level as they never bother oncoming drivers on unlit French N rds. At pointed out, I emailed Citroen for the definitive answer & was told benders are not required & as pointed out they do create hotspots on lights which can't be good. I have never heard of any UK driver being nicked in France for having not stickers on their headlights.
Thanks Received: 10 in 7 posts
22-04-2013, 08:49 AM
(This post was last modified: 22-04-2013, 08:51 AM by Kickstart.)
The replies above are all in good faith but the fact remains, on my 2009 XTR when I checked my beams against a white garage door, there was a big kick up on the left hand side. No way is mine a flat beam, therefore I used beam deflectors when I took my car to France.
Try yours and see, yours might be ok. Or not!
Kickstart
