  • 27 Vote(s) - 2.67 Average
Central locking fault
Sad
Hi there, just picked up a 2004 Berlingo forte 1.9 D which is great apart from no central locking. I can lock the doors manually but not with the fob or the interior locking button! The fob operates the immobilizer but none of the doors, it attempts to as you can here it click.
Can anyone shed any light on my problem please,
regards,
Thomas.
Does it react at all when pushing the interior button?
Hi Andre, yes it clicks but that is it unfortunately!
Fuse F15 or F16 Drivers fuse box would be my first idea if the central locking doesn't work from plip or interior button???
Worth a lookSmile
[-] The following 1 user says Thank You to adam3rdcanvey for this post:
  • tregeseal
Hi Adam, I will give that a go tomorrow, thanks a lot mate.
[-] The following 1 user says Thank You to tregeseal for this post:
  • adam3rdcanvey
cheers mate.
keep us posted as to results.........
Will do,
cheers
Hi guys, fuse is fine! Any other thoughts?
Hmmmmmm.... knew it wasn't that simple......
Do the indicators flash when using fob? Indicates signal received by locking motor.....
Check the wiring loom from drivers door to main body of vehicle..... broken wires, water ingress etc.....
Could be a BSI issue at the end of the day though, give these a try first and keep us postedSmile
Hi again, seeing I purchased the car on Monday this week from a independent car dealer I phoned him to see if he could help and he was good enough to get it into our local Citroen main dealer who I think has changed the BSI unit at a cost of £367 apparently. My Wife took care of it all as I was working all day bless her and there was no paperwork to verify what they did but it works great now. Only thing is I have now got the service spanner showing! Does anyone know how to get rid of that?
Thanks again.
Last Post: JPCoetzee
Today 03:52 PM
OIL Drip
Today 01:49 PM
Today 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
