Threads: 9
Thanks Received: 3 in 2 posts
Thanks Given: 2
Hi all,
I am getting a little worried with my berlingo, it is a 1.6 hdi model.
It ticks quite a lot, even from start up.
When you have the passenger window open and go past houses or fences you can hear it more.
I have had the glow plugs replaced and also have run through some injector cleaner and no difference.
Would anybody have any ideas? I am getting worried and I have a couple of long trips to do soon.
many thanks
Martin
Threads: 16
Thanks Received: 31 in 22 posts
Thanks Given: 3
What does this ticking noise sound like? Is it continuous, does it increase and decrease with engine speed? I've noticed mine occasionally makes a clicking type sound that doesn't seem to change with engine speed, it's never got any worse and I've done a good few thousand miles since I first noticed it. I noticed my air filter box seems to have quite a bit of movement in it and it sounds like the clicking is coming from the back of the engine bay when I've heard it so I suspect it's probably the air filter box vibrating thats causing the noise in my case.
Threads: 9
Thanks Given: 2
My noise does go up and down with the engine revs. My air box was loose as well as the bracket had broken but got a new bracket and thats ok now.
It kind of sounds like tappet noise but not sure what that could mean
thanks
Threads: 81
Thanks Given: 165
20
Check for leakage around the injectors?
Its not something silly like a piece of grit embedded in the drive belt?
If you could isolate the noise it would help-sounds silly but some earplugs would allow you to hear only the ticking up close or even a length of broomstick pressed against the engine in various locations and 'listen' with the other end pressed against your ear.
Threads: 9
Thanks Given: 316
15
at a guess injector blowing - any oil around the injectors?
Threads: 9
Thanks Given: 2
Hi,
I've just investigated further.
I took the cover off the top and listened. It sounds like the injectors ticking and the left one is slightly louder than the others.
Also there is a bit of oil round them, but not sure if from them or from the other thing that sits inbetween them.
Is this helpful?
thanks
martin
Threads: 9
Thanks Given: 2
Hi, cheers. I have read that. Sounds worrying.
I.might take it to the garage and see what they say. Could cost me a bit then
Threads: 9
Thanks Given: 316
15
Hi Martin - just noticed I called you mike in my last post!!!!! haven't even had a drink yet lol
if you have caught it early it could just be the one injector needs to come out and the other 3 just nipped up. But I would still flush the engine and change the oil and filter to be safe.
Threads: 9
Thanks Given: 2
30-04-2013, 05:31 AM
(This post was last modified: 30-04-2013, 05:32 AM by Swarv.)
Hi,
I did wonder why, but I didn't question it......
ok - hope that's all then. I'll see what the garage say about it and when they can have it. Hopefully soon as its due on a few long runs soon.
also the oil and filter only got changed in jan.
thanks for all this.
