Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 3
The berlingo is in for a minor service, they offer an oil and fuel flush for an extra 20 quid. Worth it or just easy profit for them?
Threads: 51
Thanks Given: 23
I haven't heard anyone say much good about flushing. Most of the things I've read seem to have people concerned about dislodging stuff which could make its way into fine oilways. Having said that I have used a flushing oil but on a BL A series engine which could probably cope with anything.
If you've used the proper oil and changed it at the correct intervals you shouldn't need to have the engine flushed.
Malc
Stupid computer!
Threads: 5
Thanks Received: 30 in 22 posts
Thanks Given: 1
No.
Easy profit, waste of money.
Threads: 39
Thanks Given: 1
4
No
I would put the money towards more frequent oil changes.
Peter
Threads: 29
Thanks Given: 67
20
Not many diesels recommend engine flush before oil change, what is yours ? Petrol engines with hydraulic tappets benefit from an occasional flush.
Threads: 12
Thanks Given: 16
37
I would strongly recommend a flush on the 1.6 HDI, especially the Forte flush. I have nothing to gain, and dont believe in additives, but for this engine it does wonders.
Threads: 20
Thanks Given: 2,126
18
As I have said before,I use Forte flush& have done for years.:thumbsup:
Strawberry flavoured windows
Threads: 83
Thanks Received: 397 in 340 posts
Thanks Given: 179
21
Summary
amned if you do and damned if you don't
Whatever you choose,do it yourself so you know its actually been done.
Threads: 67
Thanks Given: 1,045
I use Wurth flush when I consider it offers a benefit; it's the most readily available of trustworthy brands. I don't believe it should be sold up as an "extra" to people; like putting coolant in the radiator it may be considered part of a process deemed necessary by qualified tradesmen.
