Hesitaion and Juddering
Threads: 2
Thanks Received: 1 in 1 posts
Bought my 1.6 HDI in January, almost from first day I noticed hesitation under gentle acceleration, also I have had violent juddering and loss of power for up to 20 seconds - this is completely intermittent and clears itself. I initially thought it could be a fuel issue but have ruled that out by buying all different btands at different places. Been back into dealers twice, first time they found nothing and gave it a polish and an air freshener (really useful!) Second time they say they found carbon on exhaust valves and said they may not have been closing properly - they cleared this but no difference. They tell me I have to drive at no less than 60mph for 10 minutes every week to avoid problems with particulate filter - although one lad said 60mph for 10 minutes IN THIRD GEAR!.
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
You're lucky they never charged at least £30 before checking, have same problem but dealer cannot now find the recurrent fault and I feel that Citroen UK are dismissing my concerns- several codes came up and they changed the fuel filter when it happened the first time, but charged me. Ask the dealer to check for fault codes.
Former 2011 Mk3 XTR owner  alut:
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
A good run at higher speeds is apparently the in-thing to clear the dpf on trafic bound cars but as taxi says a diagnostic check would be a benefit -try a different dealer Citroen or peugeot
Threads: 2
Hi - thanks for replies and suggestion.
This is a brand new vehicle under warranty and no way whatsoever will I pay a penny for them to check it out - for a dealer to do that is a disgrace, on trawling online this does seem to be a common problem, and I have seen a comment "Oh it,s a Citroen thing, you have to live with it" hell no - it,s a brand new car and it will drive like one or it's going back "not fit for purpose" I am totally brassed off after having my previous car for 12 years and never a fault in 160,000 miles and still happily driven by my friend - worth only scrap value but too good to scrap. I now have a new car which I am avoiding driving until it's sorted as it's dangerous - turning right across oncoming traffic or overtaking you never know when it may judder and loose power.
Threads: 96
Thanks Given: 709
01-05-2013, 11:35 AM
(This post was last modified: 01-05-2013, 11:41 AM by taxi.)
(01-05-2013, 10:45 AM)tinhorseman Wrote: Hi - thanks for replies and suggestion.
This is a brand new vehicle under warranty and no way whatsoever will I pay a penny for them to check it out - for a dealer to do that is a disgrace, on trawling online this does seem to be a common problem, and I have seen a comment "Oh it,s a Citroen thing, you have to live with it" hell no - it,s a brand new car and it will drive like one or it's going back "not fit for purpose" I am totally brassed off after having my previous car for 12 years and never a fault in 160,000 miles and still happily driven by my friend - worth only scrap value but too good to scrap. I now have a new car which I am avoiding driving until it's sorted as it's dangerous - turning right across oncoming traffic or overtaking you never know when it may judder and loose power. I, and another Forum member, have been informed by Citroen UK that they cannot tell dealers what to charge to check warranty repairs-the dealer will ( or should ) waive the charge if they can find a fault. When mine went into the dealers on a tow truck they told me it was caused by contaminated fuel, but on the invoice they said it was fuel circuit fault.
:brickwall::brickwall:
Check that there is no problem with " turbo underboost "
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
I find if I use a certain supermarket fuel for a while my Berlingo looses power and judders then clears its self. My friend said to try a diesel rinse to clear the s**t out and it worked and to use V POWER now and then.
I DO MISS MY BERLINGO
Threads: 96
Thanks Given: 709
What diesel rinse do you use?
Threads: 63
Thanks Given: 552
(02-05-2013, 07:02 PM)taxi Wrote: What diesel rinse do you use?
Ah good question I can't remember, he did say don't buy a cheap one get the most I can afford.
Threads: 96
Thanks Given: 709
Cheap one, then.lol.
Threads: 63
Thanks Given: 552
(02-05-2013, 08:24 PM)taxi Wrote: Cheap one, then.lol. I think i paid £16  cratch:
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
