  • 10 Vote(s) - 2.6 Average
12v socket fuse
My 12v socket isn't working & I need to check the fuse. Has anyone found an easy way of accessing the fuse in the glove box ? Can the whole thing be hinged down into the footwell ?
Ha! getting it out is easy.
Getting it back in:
Superglue a cable-tie to the top of the new fuse.
Simples!
Even once you get the glove box door and frame off, its still squirreled away in an extremely awkward position - just about reachable with long fingers to remove. But getting back in is even trickier, as the available gap is only just wider than a fuse.
I eventually managed by gripping the fuse with the removal tool and maneouvering it into position held perpendicular between my middle and ring finger.
Expect to do a lot of swearing. What a F*****g stupid position to put one of the most likely fuses to blow.
The Bus II: 2019 XL Flair 1.2
(03-05-2013, 07:47 AM)Guanajuato Wrote:  Even once you get the glove box door and frame off, its still squirreled away in an extremely awkward position - just about reachable with long fingers to remove. But getting back in is even trickier, as the available gap is only just wider than a fuse.
Takes me 2 minutes to superglue.
3 seconds to put fuse in.
Have you got a photo of your adapted fuse setup ?
Tried again today, but fingers like sausages do not help
Rolleyes
Last Post: rom4ik
Today 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
