Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
cratch: Belt?
Threads: 32
Thanks Given: 18
Alternator bearings, pully bearings, belt? Ivwouldn't drive it until it was sorted if it were mine!
Threads: 67
Thanks Given: 1,045
Frayed cambelt or aux belt; something flapping on a placcy cover.
Threads: 67
Thanks Given: 1,045
First thing I'd do is free; remove the two 10mm bolts holding the top cover over the timing belt and check that bugger for fraying - it's only 17mm wide to begin with. :eek:
Hi,
Did you ever find the cause?
Thanks.
