03-05-2013, 02:36 PM
Hi all,
I wonder if you could help me.
My 1.4 petrol multispace seems to randomly decide that its not going to start. When the key is turned, all the lights on the dashboard come up as normal then when the key is turned to the sprung loaded position to operate the starter, the nothing happens, no engine spinning other than a light clicking noise coming from under the dashboard on the right hand side where I think the BSI is located.
I presume the imobiliser is ok as I do hear this small relay click from the right hand side when the key is turned fully to start but nothing like a starter motor click.
The trouble is that the van will go a couple of weeks maybe more before it will have an episode of this happening and then if its left alone for a few hours, the car will suddenly start like nothing has happened. Wierd!
Does anyone have any idea what this could be.
Having a hunch, I have noticed by the way that the carpet is wet occasionally just below the drivers seat and I get a lot of water dripping from the drivers side wheel arch.
I've heard water can get in to the BSi but would that be causing these starting issues?
How would I check for water ingress to the BSI and is it easy to remove to check?
Thanks very much in advance.
Cheers, David.
BTW the van is epic when its working albeit a little slow :-)
Cheers, David.
