  • 5 Vote(s) - 3.4 Average
Clutch cable snapped twice!
Hello all found the site through google and have found it very useful. I drive mk2 berlingo it's a 2005 with 112 thousand kms. Last week the clutch cable snapped and I had it replaced by a mechanic with a genuine citroen replacement cable. But today having driven about 10 miles the new cable snapped again. Now the mechanic thinks I may need a new clutch and I will also have to get another cable now too. Has this ever happened anyone else? Just looking for advice before I go changing the clutch.
I had a fiat cinquecento a good few years ago and in a space of a few months two clutch cables had snapped. On the second time the AA guy who came to my rescue told me that it can be a sign that the clutch is on the way out, I didn't hold on to car long enough to find out though.
Thanks for the reply maybe I will go ahead with getting a new clutch then.
Is it breaking the nipple off at either end ? We had one on a Corsa which had worn at the pedal end and it was twisting the cable as it pulled so it frayed and broke. Is your clutch slipping yet ?
if the pedal is stiff the clutch is almost out time to replace.
It is snapping at the engine end. The clutch pedal has always been stiff I haven't noticed it getting any stiffer.
If the shaft that fits into the gearbox to which the cable is attached is sticking, it will wear out the thrust bearing and pressure plate of the clutch assy. Seeing that its' broke two cables the damage is probably already done. While the gearbox is out get the shaft lubricated at the lower end and the thrust bearing sleeve.
Ok thanks its with the mechanic at the moment should have it back Friday.
(06-05-2013, 08:29 AM)brodfather11 Wrote:  If the shaft that fits into the gearbox to which the cable is attached is sticking, it will wear out the thrust bearing and pressure plate of the clutch assy. Seeing that its' broke two cables the damage is probably already done. While the gearbox is out get the shaft lubricated at the lower end and the thrust bearing sleeve.
That was exactly what was happening. Mechanic explained and showed me the shaft that you were talking about :thumbsup:
Mileage
Last Post: Taffy747
Yesterday 11:51 AM
Yesterday 09:17 AM
Yet another ABS fault
10-05-2026 10:13 PM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
