  • 8 Vote(s) - 2.38 Average
2005 multispace rear centre seatbelt stuck.
hi have any of you lads had the rear centre seat belt lock up. this happened a while ago and i removed the seat and as i laid it upside down it released and was ok for a while. well a couple of weeks ago it happened again removed the seat again but no way will it release .i tryed getting to it but is a hard one as its fitted into the middle of the rear seat and i havent manadge to get to it.the seat was folded down and the belt stopped it from being put back up. ive removed the bottom fixing temp. has anyone resolved one.
(04-05-2013, 08:16 PM)landcrab Wrote:  hi have any of you lads had the rear centre seat belt lock up. this happened a while ago and i removed the seat and as i laid it upside down it released and was ok for a while. well a couple of weeks ago it happened again removed the seat again but no way will it release .i tryed getting to it but is a hard one as its fitted into the middle of the rear seat and i havent manadge to get to it.the seat was folded down and the belt stopped it from being put back up. ive removed the bottom fixing temp. has anyone resolved one.
Undo the torqx screw mounting bolts and position the folded seat so the backrest is in the vertical position, might need to just rock it slightly and this will release the "Ball pendulum type" unit holding the belt. if it does it again you will need to replace it by stripping the back of the seat. Confusedalut:
[-] The following 1 user says Thank You to Gollycrush for this post:
  • addo
Hi everyone my name is Paul glad to find you.
I have had this problem many times; I investigated the function of the plastic cap at the top of the seat belt, on top of the seat,
that has something to do with it! if it is not seated properly it doesn't seam to guide the belt correctly and the seat locks up!
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
