Bluetooth Music Streaming
Threads: 2
Okay, so my dad upgraded from a MK2 top of the range to a MK3 92bhp multispace. We bought the car second hand and it has only done 5k miles. #bargain However being a lad ages 16 I love to play music in the car and the car doesn't have Bluetooth at all. If i want to stream music across the speakers whats the easiest option/cheapest option for me to do? I believe that you can install it when buying the car and wondered if i could get hold of the part that fits into the back of the radio?
Thanks, Michael
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Not sure about Bluetooth but the XTR comes with this
which is in the glovebox.
I DO MISS MY BERLINGO
The following 1 user says Thank You to philip for this post:1 user says Thank You to philip for this post
• addo
Threads: 81
Thanks Given: 165
20
Or an fm transmitter-you plug your device into it and it converts the sound to FM signal which the car radio will pick up.
You will not then get into bother by potentially wrecking the car..
ebay
Threads: 73
Thanks Received: 45 in 34 posts
The.fm transmitter is a Great and easy solution. Plugs into the cig-lighter and plugg your phone into the module. And done. That easy. Many different types to choose from
https://www.google.no/search?client=safa...buUjpY01Zs
The following 1 user says Thank You to Tikki for this post:1 user says Thank You to Tikki for this post
• MudFT
Threads: 5
Thanks Received: 30 in 22 posts
Thanks Given: 1
14-05-2013, 09:53 PM
(This post was last modified: 14-05-2013, 09:56 PM by MudFT.)
(14-05-2013, 09:09 PM)Tikki Wrote: The.fm transmitter is a Great and easy solution. ................
Anyone who says they get decent quality from a FM transmitter has absolutely no comprehension of quality audio!
On a scale of 1 to 10:
FM transmitter = 1
BT = 7
The best you will get with BT is:
http://www.amazon.co.uk/dp/B0057BAB60/?t...B0057BAB60
A power adapter will be required for car for above (£5 ish).
You can spend far more on BT, however it is impossible to get better BT quality than using the above.
The following 1 user says Thank You to MudFT for this post:1 user says Thank You to MudFT for this post
• RolyG
Threads: 10
Thanks Received: 5 in 4 posts
Thanks Given: 24
http://www.belkin.com/us/p/P-F8M117
I got one these a while back and it works pretty well, the sound quality Is alright. The stereo in the berlingo is not the greatest anyway and this thing just works with minimum fuss.
Threads: 5
Thanks Given: 1
15-05-2013, 07:06 AM
(This post was last modified: 15-05-2013, 07:07 AM by MudFT.)
(14-05-2013, 11:58 PM)Silent_Bob Wrote: http://www.belkin.com/us/p/P-F8M117
BT has two standards for audio, A2DP or VDP.
A2DP being the superior and acceptable to most (not me).
Any audiophile would not go anywhere near BT.
A2DP Hardware:
The only difference is signal strength (range) and the prevention of interference.
For simply streaming music the Logitechs range and prevention of interference are ideal for a car.
You will not be able to improve the audio quality any further using BT than that can be achieved using the Logitech.
Hence:
If you want to simply stream music buy the Logitech.
Cheaper (£10 eBay) are available but interference may be a problem in a car.
If you want quality, use a cable.
(05-05-2013, 07:12 PM)Michael Humphreys Wrote: Okay, so my dad upgraded from a MK2 top of the range to a MK3 92bhp multispace. We bought the car second hand and it has only done 5k miles. #bargain However being a lad ages 16 I love to play music in the car and the car doesn't have Bluetooth at all. If i want to stream music across the speakers whats the easiest option/cheapest option for me to do? I believe that you can install it when buying the car and wondered if i could get hold of the part that fits into the back of the radio?
Thanks, Michael
the absolute best way of getting your music playing through the original stereo is by fitting a parrot mki9200, this will give you a phone kit, music streaming, ipod connectivity, usb, 3.5mm stereo jack plug.
Threads: 0
(20-05-2013, 11:30 PM)dc alarms Wrote: (05-05-2013, 07:12 PM)Michael Humphreys Wrote: Okay, so my dad upgraded from a MK2 top of the range to a MK3 92bhp multispace. We bought the car second hand and it has only done 5k miles. #bargain However being a lad ages 16 I love to play music in the car and the car doesn't have Bluetooth at all. If i want to stream music across the speakers whats the easiest option/cheapest option for me to do? I believe that you can install it when buying the car and wondered if i could get hold of the part that fits into the back of the radio?
Thanks, Michael
For me the THB Bury CC 9068 APP looks promising and i would prefer it over the parrot.
(24-05-2013, 12:33 AM)hantl Wrote: (20-05-2013, 11:30 PM)dc alarms Wrote: (05-05-2013, 07:12 PM)Michael Humphreys Wrote: Okay, so my dad upgraded from a MK2 top of the range to a MK3 92bhp multispace. We bought the car second hand and it has only done 5k miles. #bargain However being a lad ages 16 I love to play music in the car and the car doesn't have Bluetooth at all. If i want to stream music across the speakers whats the easiest option/cheapest option for me to do? I believe that you can install it when buying the car and wondered if i could get hold of the part that fits into the back of the radio?
Thanks, Michael
For me the THB Bury CC 9068 APP looks promising and i would prefer it over the parrot. im an auto electrician, and i fit phone kits all the time. the parrot is a much better kit than the thbury.
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
