  • 13 Vote(s) - 3.31 Average
Headlight bulb
How do you change the n/side bulb on a 57 1.6HDi?
O/side one is difficult enough, other side looks like a complete nightmare. There is no way to fit your hand without removing half the electrics.
Wonder how many hours Citroen dealers quote?
Looks quicker to change the clutch, or tile the bathroom...:brickwall:
Casting my mind back, you have a good point. Its ridiculous just for a bulb change. I think its a chapter in Haynes.
I think if you remove intake pipes and fuse box lid, there is just enough room for a small hand. (Wife/ChildSmile)
Did mine in leather gloves to get the cover off the rear of the headlight though,
Will rip you to shreds otherwise!!
[-] The following 1 user says Thank You to adam3rdcanvey for this post:
  • j90xxx
Our bathroom needs tiling - feel free to pop round and I'll change the lamp bulb while you're at it!!!
[-] The following 1 user says Thank You to jamesf for this post:
  • j90xxx
You're on!
Tiling looks much easier than n/side bulb, although it hasn't actually blown yet.
Working myself up to the job.
Might fit a pair of Nightbreaker Plus bulbs as had good reports on the Forum.
Also like the idea (thanks, Adam) of employing small (vertically challenged) people to do fiddly jobs. Is there an Employment Agency for them?
If not.......
Dragons Den??
Had another look at how to replace near side headlight bulb today.Confusedcratch:
Then closed the bonnet and made a cup of tea.:thumbsup:
If it ain't broke...... Smile
[-] The following 2 users say Thank You to adam3rdcanvey for this post:
  • j90xxx, ron
But it will break.
And it will be raining.
And dark.
And frosty.
Would rather change them both now.
While it is warm.
And sunny.
Or should I make another cup of tea?
(06-06-2011, 06:40 PM)j90xxx Wrote:  But it will break.
And dark.
And frosty.
While it is warm.
And sunny.
Did mine t'other day an' it's a right bugger. It's about as much fun as performing your own testicular surgery with a hole punch and a 100 watt soldering iron.
I took off the top grille, undid the two accessible headlamp screws and unclipped the top mounting from the body bracket and pulled the headlamp unit as far forward as I could.
That gave me room enough (only just) to get the cap off and change the headlamp bulb and the parking light bulb.
Changed sidelight bulb.
After a month it blew.
Changed it again.
Now changed headlight bulbs for Osram Nightbreaker Plus.
They make loads of difference.
Getting pretty good at it now. (About 20mins instead of an afternoon!)
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
