Threads: 28
Thanks Received: 7 in 6 posts
I've looked around the forum trying to find out where the horn is on a Mk3. I've got twin air horns I want to fit and need the wires off of the original horn. I've tried following the sound of it but just can't see it! I think it may be behind the fuse box on the N/S? Anybody know where it is? Is it simple enough to get to?
Threads: 52
Thanks Given: 87
5
I've been looking to replace mine too (the stock horn is a real joke) but alas it is well hidden. Behind the front bumper on the left side (viewed from inside). Can see it if you get it up on a lift and take off the cover plate underneath the car.
Threads: 9
Thanks Received: 18 in 15 posts
Thanks Given: 21
(10-05-2013, 05:12 PM)til5101 Wrote: Sweet thanks 3rensho!
Let us know how you go on fitting those, hope there's enough space there, as I was thinking of doing the same thing.
2011 (61) Multispace XTR 110 in Kyanos Blue
Threads: 28
Ive got the horns in, you can just get to the orginal from underneath. Ive appeared to have blown the fuse for the horn though :/ anybody know where the fuse is? I think its a 20amp?
Threads: 83
Thanks Received: 397 in 340 posts
Thanks Given: 179
21
13-05-2013, 06:17 PM
(This post was last modified: 13-05-2013, 06:18 PM by evdama.)
Its a 15A miniblade, in the engine compartment fusebox.
Position F2 just in front of the middle of the 3 multiplug connectors
Threads: 50
Thanks Given: 743
DO NOT try to run something like twin horns direct from
the standard wiring harness. Use the original wiring to the horn
to activate a relay, then take a new, separate supply (which is fused at around
25 amps) from the battery to the new horns via the relay.
If what I have said here goes over your head then find someone who is
competent with vehicle electrical systems.
The following 1 user says Thank You to Ol'Jeffers for this post:1 user says Thank You to Ol'Jeffers for this post
• addo
Threads: 29
Thanks Given: 67
20
It definitely needs a relay to run the horn compressor, don't just try a bigger fuse or you'll melt the wiring
Threads: 28
It's all good! It's all wired in with the relay properly. I've got a 30 amp fuse between the relay and the battery. I managed to squeeze the horns between the n/s headlight and the wing and then cable tied them. I'd recommend fitting air horns the raphosa, purely for the shits and giggles when someone is not expecting it!
