Threads: 67
Thanks Given: 1,045
The large yellowy-beige one looks promising. Where does it go to?
Threads: 5
Thanks Received: 4 in 4 posts
That's what I thought with it being quite beefy. It's run into where the rear lights are and where the wires run up to what I assume will be the interior light and maybe the brake light and demist in the tailgate
Threads: 67
Thanks Given: 1,045
It could be a demister feed. Any numbers between the asterisks?
Threads: 67
Thanks Given: 1,045
Doesn't tally with the demister circuits, from memory. Might be the extra feed that someone else mentioned recently.
Threads: 5
Thanks Received: 30 in 22 posts
Thanks Given: 1
14-05-2013, 08:17 AM
(This post was last modified: 14-05-2013, 08:18 AM by MudFT.)
Get a multi-meter with sharp probes.
Threads: 5
No idea what the beige/yellow one is got sharp pointed multimeter ran it over battery to test and read 14+v running. But when on cable nothing and even tried it with demister button on but nothing. Seems odd for being such a chunky cable too
Threads: 5
Just been out there writing numbers down off cables hoping someone can point me in direction. Here's what I have *8450*8051*2200G*289*520A*A07A*811*2630*2101*M302G(which I guess is earth judging by colour being green/yellow)
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
Could it be a harness for tow bar wiring?. There might be fuse position for it but no fuse fitted ?.
