Threads: 5
Thanks Received: 1 in 1 posts
Hi I'm new to this but need help I purchased a maf sensor enhansor for my last car an want to now wire it to my berlingo van it 02' 2.0 hdi! All wires goin to it are green! Wer do I connect it to?? Help please! Thanks
Threads: 32
Thanks Given: 18
Maf sensor enhancer not required, suggest refund.
Threads: 63
Thanks Given: 410
WTF is a MAF enhancer sensor???
Threads: 5
Why is it not required? Will it not make a difference?
Threads: 63
Thanks Given: 410
MAF = Mass Air Flow sensor, detects how much air is flowing through the induction at a given time and sends signal to the computor or ECU which makes adjustments to the running of the engine, based on the information received. Cannot for the life of me see how this can be enhanced, air will either flow when the engine is running or cease when shut down....
Threads: 5
Well I have it wired up to it now based on instructions form another person! Def a dif is made, noticed mores torque an more of a pull in gears, it's basically a resister, only costs couple a quid!
Threads: 62
Thanks Received: 715 in 612 posts
Thanks Given: 220
50
A result is a result at the end of the day, well done.
Sounds like a good way to fool the system :woop:
Serieal Berlingo owner
Threads: 32
Thanks Given: 18
All it does is over fuel the engine. Have you ever heard or bore wash? Google it.
Threads: 5
Thanks Received: 30 in 22 posts
Thanks Given: 1
Snake Oil!
If it makes you happy.
At times I wish I had the lack of conscience to sell such crap. I would be very rich.
The following 1 user says Thank You to MudFT for this post:1 user says Thank You to MudFT for this post
• andy-womble
