Threads: 3
Hi all,
Changed rear engine mount, garage pressed in a new bush and now steering wheel vibrates at idle?
So rather than the engine attempting to rip itself from its mountings each time I turned if off it I trying to vibrate itself to bits whilst idling ! Bloody Shitroens...got to love it but Japanese it aint!
Thanks Given: 188
23
Sounds like something aint been fitted right or is under strain causing the vibration.
Are we there yet?????
Threads: 20
Thanks Given: 2,126
18
Was it assembled & mounted correctly?Cheap pattern part?
just my idle thoughts.
Strawberry flavoured windows
Threads: 32
Thanks Given: 24
Had the same with mine after changing to a polybush. If you used a standard mount it will quieten down.
Threads: 20
Thanks Given: 2,126
18
A bush is not a bush if it's cheap crap.Orientation is important when fitting bushes,mostly the hollows are horizontal but not always.
In the words of the ancient prophet--RTFM.:thumbsup:
