  • 2 Vote(s) - 3.5 Average
head gasket
hi im new on here i wonder if any one can advice me the rac have said i need new head gasket i would i know if the block is cracked it didnt overheat or anthing just sprayed water out only on a long journey i have a berlingo multispace forte 2001 many thanks
What motor is in it?
Quite often the gaskets die of old age. A light skim cut, new bolts and it's good to go; you normally replace the radiator cap, thermostat, water pump and timing kit at the same occasion.
(15-05-2013, 10:10 AM)addo Wrote:  What motor is in it?
19 00
would it need to have a skim cut and much would that come to roughly
There's always light corrosion to the face of the head where it contacts the gasket; water seeps through and eats a little of the alloy away. You'd have to ask people closer to home for the price of what I call a "basic service" - chemically clean the head, new valve stem seals, skim cut and touch up the valve seats if necessary.
You can get just the skim cut done sometimes, but then removing all the shavings thoroughly will be your responsibility.
many thanks for your help
Last Post: BigVtwin996
Today 12:10 PM
Eolys replacement tank
Last Post: jw4821
Today 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
