  • 5 Vote(s) - 2.4 Average
Running a domestic chest freezer!
Almost every time we make a trip to the UK we haul along our chest freezer (it's not that huge) and plug it into the mains in my mum's garage,then when we are ready to come home everything is frozen nicely and it usually stays that way until we get home to Belgium.
Mum lives 30 mins from the tunnel at Folkestone and then it's nearly 3hrs to home from Calais.
I say lives,she died suddenly last October from cancer,so we now have a bit further to go,to Felixstowe,where my brother lives.
So,I decided to look into running the freezer off an inverter.
The first thing to do was see what amp/wattage the freezer was,turns out to be 150w,so I purchased a 300w inverter to err on the side of caution.
Next was to run some heavy cable (I used motorcycle battery cable) from the battery,around the back of the bulkhead,underneath the car and into the boot.The cables are protected with convoluted conduit and ran seperately and secured along the brake pipes.
The side panel in the boot was removed and the inverter was connected.
Did it work? Yes it did,even the milk was almost frozen when we got home!
2010 XTR in black with bells and whistles
[Image: 5A50i.jpg]
[-] The following 1 user says Thank You to XTR for this post:
  • whitebus
Is it because you get better horse meat here than in Belgium ? Big Grin
  • whitebus
(20-05-2013, 06:31 PM)ffrenchie Wrote:  Is it because you get better horse meat here than in Belgium ? Big Grin
Not quite,there are many things you can't get in Belgium.
Mind you,meat is something we usually buy from a local butcher in Whitstable,it's much cheaper and of a higher quality than we get here in Belgium.
And I don't eat horse meat,not knowingly anyway Rolleyes
[Image: 5A50i.jpg]
  • whitebus
I'm surprised a 300w inverter would start a fridge compressor. Compressors can take up to 6 times their running current during the first second of starting. They have a seperate start winding that is brought in by a relay. Look up 'split-phase motor' on wiki
It will be having a hard life
[-] The following 1 user says Thank You to Fletch for this post:
  • whitebus
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
