Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
happened to me on the way home from work, wouldnt budge, def not clutch as i was able to start it and stall when i released it, in the end i gave the gear stick a right good shaking and it came free, done a google search but cant find anything effecting later shape, alls fine now and is going into all gears no problem, any ideas what could of caused it?
Threads: 12
Thanks Given: 16
37
Maybe something fell into the gear cable mechanism. I would check the gear oil personally, because 5th gear is always the 1st to die if the oil level is dropping low.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• finny
Threads: 12
Thanks Given: 7
driven 120 miles today and its been fine, i will ask my mechanic buddy to check the oil
