  • 3 Vote(s) - 3.67 Average
Wheel bearings
Just booked in to have my wheel bearings changed, terrible roaring noise from the front offside. The cars only done less than 50000 and according to Haynes these bearings should last the life of the motor. is this a sign of things to come ? I wonder. Anybody had the same experience? Confusedcratch:
I had to have a front one replaced at about 70k, can't recall which side. Other one is still OK.
I've told them to replace both sides, just to balance it up like.
I had to have a wheel bearing replaced on the front nearside 2 months ago. The seal had failed and water had got in and ruined it. Bearing had done 65k.
I think that may have been my problem, I hit some pretty horrific floods last winter.
Talos,I would replace both sides as well,they both do the same amount of work.You also have the peace of mind.:thumbsup:
  • RolyG
Yep that's what I thought so I booked it in for that, I figure they might as well whilst its on the ramp and check the gaiters too.
(24-05-2013, 02:39 PM)Tomcat3 Wrote:  I had to have a wheel bearing replaced on the front nearside 2 months ago. The seal had failed and water had got in and ruined it. Bearing had done 65k.
(24-05-2013, 06:49 PM)ron Wrote:  Talos,I would replace both sides as well,they both do the same amount of work.You also have the peace of mind.:thumbsup:
UPDATE
Both bearings changed at a local garage (trusted) £175 inc vat, I was well pleased with that, I had expected to pay at least that for each wheel.
I don't subscribe to this theory, last vehicle I changed a wheel bearing on was my daughter's Corsa and the inside race was seized due to a failed seal. The other side was fine and has done another 50,000 miles now with no problem. It works for brake and suspension parts that need to be kept in balance.
I always find here, nearside chassis items go first due to the rough shoulder.
  • ron
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
