Thanks Received: 1 in 1 posts
I have fitted a new (second hand ) rear axle. 2003- 1,4petrol.
The ABS connections is different in the new axle.
Will the ABS functione if I get connection,or .....?
Threads: 67
Thanks Given: 1,045
If the donor vehicle had a similar system then it may be you only have to change the plug. Otherwise, what about installing the original sensors?
Threads: 9
Thanks Given: 316
15
if the original sensors wont fit then you have no option but to remove the connectors from the abs sensors - cant see there being any issue with a small bodge.
I connected the sensors. After driving about 200 meters, the ABS-light
came on.:brickwall: It is propably a different signal from the "new" axle..
