  • 4 Vote(s) - 2.25 Average
Electrical issues
New to the Berlingo/partner world but definetly not new from the Psa scene previously owning 306dt power 170bhp+
The van is a s reg 1.9d
Any way issues I have
Windscreen wipers work only at full speed once at full speed I can knock it to the next speed but it will judder and go slow almost stopping and some cases actually stopping but I can still hear the relay clicking. When this happens the moror clicks and bangs like its lose. I also have no washer jets iv tested the pump which works fine I have no power going to it. The wipers also don't work.
I'm figuring that a new stalk and wiper motor will cure this. How ever it has once perfectly worked fine smooth operation on all speeds but still no washer jets.
Interior fans don't work at all I'm suspecting the resistor back to be the problem here.
Every time I turn the car off my CD player resets as if there isn't a memory live. The CD player worked perfectly fine in my previous car.
Iv checked fuses and checked things over with a multimeter and advice pointers will be great.
Cheers
Hi there it sounds like your blower resistor pack is dead and if its an aftermarket radio and you wired it in I would say you havn`t put a permanant live to it. Plenty on here about what wires to change over or patch leads. Your wiper/stalk problem does sound like the stalk has worn on the contact traces. Ive had this happen on mercs and renaults over the years.
Cheers for the Info regards stereo it's a plug and play one no wires needed to cut just plugs into the exhausting loom
Cheers
(28-05-2013, 09:39 AM)Jenkosowls Wrote:  Cheers for the Info regards stereo it's a plug and play one no wires needed to cut just plugs into the exhausting loom
Cheers
Best have a lie down after you've done it then :lol:
  • addo
You better have a read up on the radio issues because a few have done as you say and I think they had problems and had to swap a wire round to get round it. Im sure one of the members will pass by and let you know which wires to swap.
Cheers
Haha ifails for you!
The new head unit should have yellow and red wires with a pull apart connector in a sleive.
Swap these over so the red feeds the yellow and then retest.
[-] The following 1 user says Thank You to tucker for this post:
  • Jenkosowls
(28-05-2013, 09:41 PM)tucker Wrote:  The new head unit should have yellow and red wires with a pull apart connector in a sleive.
Did This and it solved that problem thumbs up
Currently still having the wiper problem. I swoped the stalk off my old 306 the only difference being it has rear wiper function. Now this to also didnt work so can rule the stalk out as the problem. It only worked on full when pressing the stalk down fir single wiper operation it didnt work either. If I pulled the stalk towards me on a 306 it operates washer jets they worked except didn't operate the wipers.
I cleaned up the contacts inside the Berlingo stalk but still having the same problem. Except I tried the stalk out of the cowling pulled it like I did on the 306 and it operated the washer jets but no wipers. It appears the cowling restricts the stalk to up and down movement only. So I can rule out the stalk now it's something else
Spot the Berlingo(s)
Today 05:54 PM
knocking from rear
Today 04:59 PM
Last Post: Andhall
Today 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Today 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Today 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
Yesterday 08:28 PM
wipers
Yesterday 06:17 PM
Last Post: xavier988
Yesterday 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
