28-05-2013, 04:57 PM
Hello First post so here goes.
Berlingo Multspace 1.9 D MFWJZ mk1 2001 DW
I have been living with a rough initial tick over, that varies between 825 revs to normal, for some months now, starting in the winter.
What I do is use the accelerator to get over this .
It seems like only 2 cylinders are working from the smoke out the back if left without using the accelerator trick !
I have now checked the glow plugs individually and tested /timed the pre/post operation and all is fine no problems.
No problems too of normal running.
Once the car has moved the tick over goes to normal and solid.
Something simple ?
Thanks in advance for any suggestions
Something simple ?
