  • 2 Vote(s) - 3.5 Average
Alloys - Again
Sti8ll trying to source a set of alloys for my 2009 Berlingo Multispace.
I have found a set of 15" alloys that came off a 2002 Citroen c5 2.0hdi
Their dimensions are:-
Stud Diameter: 108 Rim Width: 6.5J
Tyre Width: 205 Rim Diameter: 15
Aspect Ratio: 65 Number of Studs: 4
Centre Bore: 65.1
Can anyone advise if these wheels would fit ?
the 108 x 4 is right and center bore, you ideally need an et of around 25 which is stamped on the inside of the rim, not sure on the tyre size, if your standard ones are 195/65/15 the 205/65/15 have an extra 2.21% rolling circumfrance which is withing recommendations
Cheers for the info Finny.
The tyre fitted on mine are 205/65 R15.
Can you explain what the ET25 refers to ?
ET is a measurement of offset for a wheel, early citroen were 15 later around 25
[-] The following 1 user says Thank You to finny for this post:
  • dellwood333
(30-05-2013, 07:56 PM)finny Wrote:  ET is a measurement of offset for a wheel, early citroen were 15 later around 25
Apparently the seller says that there is no ET number on the wheels, so I am really no further forward in knowing if they will fit or not Sad
Anyone got some 15" alloys to fit a 2009 Multispace ?Wink
I use several websites for wheel/tyre information.
One is the Miata Tire Calculator
Also I use the 1010Tires Wheel Offset Calculator
Finally, the Wheel Fitment EU site.
have a look on ebay, anything from a citroen c2/c3/c4/picasso and peugeot 206/207/307/308 will fit, you will also need the correct bolts to fit genuine wheels.
  • eame64
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
