  • 4 Vote(s) - 3.25 Average
Horn fault
Hi!
I wondered if anyone could give me a little bit of help please?
I have a Mk11 2005 Berlingo MultiSpace 1.9D that has 2 odd little electrical faults...
When the ignition is off, the horn will work as normal but when the car is running or ignition is on the horn won't work.
Also, when indicating right, the indicator flash pattern is erratic.
Thanks in advance
Steve
(01-06-2013, 09:06 AM)dw8vanman Wrote:  Hi!
Thanks in advance
Steve
common fault has happened to 2 berlingos that i have owned
remove the airbag from steering wheel,has spring clips holding it on just pop a little screwdriver in the holes on the rear and release the clips
then you will see a black wire with a spade terminal connected to the steering wheel,unplug the wire and connect a ring connector then drill a tiny hole into the metal of steering wheel then using a self tapping screw connect the black wire,this make a better earth connection and has worked twice for me
indicator erratic flash is more than likely a wrong bulb or blown bulb or the flasher relay
Have a " search " as I posted a photograph on just this same topic
Here you go, look here on the second page . http://www.berlingoforum.co.uk/showthrea...633&page=2
  • RolyG
Thank you chaps!
I have done as you both suggested and we have success!
Horn is now working, think the indicator fault maybe down to a faulty relay so will have to find that one and try it.
Nice easy little fix on a sunny Saturday.
Your help and advice is very gratefully received, thanks.
Steve
[-] The following 1 user says Thank You to dw8vanman for this post:
  • RolyG
Yesterday 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
