  • 12 Vote(s) - 3.75 Average
Brake Pressure Regulator Valve Spring
Van is a 1999.
I have a broken spring on the brake pressure regulator valve - could somebody please a) whether they are available separately, b) if so where is the best place to buy one and c) how awkward a job is it to do? Any advice would be appreciated. Thanks.
Not generally available separately OEM. There are are one or two threads dealing with this.
Folk have replaced the spring with another type, apparently it's not too easy to get at.
I don't know how similar this is.....but it says it's for a Berlingo:
http://uk.ebid.net/for-sale/peugeot-citr...540239.htm
BTW...Welcome!
Thanks for the advice and welcome. Have bought one of those replacement springs and will see how we go.
[-] The following 1 user says Thank You to tutty for this post:
  • Ol'Jeffers
Fitted new spring today and appears to have fixed the problem. Bit of a fiddle to fit as access is very limited. but perseverance paid off eventually, and swearing at it helped a lot too!
  • ron
I've found the spring on mine is detached or broken,
Anyone know how the Long end of the spring,fixes to the axle....?
called Brian... Smile
There is a metal bracket with a small hole in it that the hook end of the spring goes into. Either the hook of the spring is rotted away or the bracket is broken. New stainless steel springs are on ebay approx. £20.00 or so.
It can be a bit of a fiddle to fit , they seem to fallout of the hole very easy but don't like being put back in.
Try to use the same adjustment on the old adjuster rod as if wrong the back brakes can have too much pressure before the front ones. Could be nasty if braking on corners.
 There is a way of setting the rod adjustment as per manual but its complicated
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
[-] The following 2 users say Thank You to brodfather11 for this post:
  • Art b, Tomcat3
(03-04-2019, 01:09 PM)brodfather11 Wrote:  There is a metal bracket with a small hole in it that the hook end of the spring goes into. Either the hook of the spring is rotted away or the bracket is broken. New stainless steel springs are on ebay approx. £20.00 or so.
Ok will have to have a good look...
There is no hook on the spring ..or a bracket
Here you go this is what Brodfather is talking about https://www.ebay.co.uk/itm/Citroen-Berli...SwihVcA-yV
Its usually the hook end of the spring that has broken off.
  • Art b
(03-04-2019, 06:41 PM)Tomcat3 Wrote:  Here you go this is what Brodfather is talking about https://www.ebay.co.uk/itm/Citroen-Berli...SwihVcA-yV
Will take a look ...cheers
the ebay add is great for seeing whats missing.. Smile
your right its the hook gone.. Rolleyes
Leaking windscreen or aerial
Last Post: Guanajuato
Today 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
