05-06-2013, 11:52 AM
Hi. (always a good start) :wave:
I have a 05 Partner 2.0 HDi 4x4. Lately, the ABS seems to have gotten ideas of it's own. I first noticed it while driving in the rain; when braking, the ABS kicked in just before coming to a standstill and the rear end lifted. At first I thought the road was very slippery, but as it happened on dry roads also, I ruled that out.
Then, the next day, which was dry and
unny: everything was back to normal. Next time it rained, same behavior.
cratch:
I tried cleaning the sensor rings with pressurised air, but it made no difference. And last night, after starting and driving 50 meters, I heard a beep and the ABS light and STOP light came on. I returned to home base and took the C1 to work.
Today, everything seems to be ok again. And no error codes. I suspect one of the sensors.
I did quick forum search
tudy: but couldn't find any solutions. Is there a kind soul out there that could point me in the right direction?
cratch:I tried cleaning the sensor rings with pressurised air, but it made no difference. And last night, after starting and driving 50 meters, I heard a beep and the ABS light and STOP light came on. I returned to home base and took the C1 to work.
So I haven't bothered. Hopefully, the pressurised air did the trick. If it happens again, I'll let you know.
