05-06-2013, 10:37 PM
Hi All,
Berlingo M59, 2.0HDI Multispace Desire. 2004 plate.
First of all, it's had cruise fitted. It's enabled in the BSI, it mostly works. Radio stalk works ok.
The airbag is not working. Lexia gives the error message pictured.
The horn does not work.
Both were working in the past. The airbag light started coming on occasionally, then eventually permanently. The horn worked intermittently, now doesn't.
Now, when the sidelights are switched on, the horn comes on constantly. If I am using cruise and use the wipers or indicators, cruise cancels.
There's obviously something "wrong" with the comms 2000 or the connections in it, or whatever. Lexia reports no faults though.
Is it simply a case where I'm going to have to replace the Comms unit? I don't mind, if this is the case...
In the picture inside the wheel, can anyone tell me what the green plug is for? It just clips to the side of the airbag, and doesn't actually connect to anything...
thanks all!
Mike
thanks all!
Mike
illyme:
