  • 4 Vote(s) - 3 Average
electric window 2003 berlingo
my o/s/f electric window has stopped working- all i get when i try the swich is a clicking noise somewhere behind the dash/fuse box area.
I have checked the fuses- all ok
checked the plug in connector to the motor- getting power
i have even swapped switches all to no avail
any ideas where i go to from hear?
thanks mal
If your motor is getting power then it must be the motor at fault.try running power to it independantly.reversing polarity for up and down.if it doesnt move the motor needs looking at and or replacing.
(06-06-2013, 09:01 PM)desperatedes Wrote:  If your motor is getting power then it must be the motor at fault.try running power to it independantly.reversing polarity for up and down.if it doesnt move the motor needs looking at and or replacing.
cheers- im going to try that today- if its a failure then i have sourced a manual kit (i presume these are compatible )
well looks like it was the motor
Problem now solved by fitting manual winder at a cost of 10 quid- job done
Hi Malbro
Where did you get hold of the manual winding kit? Access to the motor and regulator looks pretty tricky. Was it?
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
