  • 43 Vote(s) - 3.26 Average
Gear Knob Removal
How the :censored: do you get the gear knob off??? The Haynes joke book says "twist & pull the gear knob off the gear lever". Yeah, right! :brickwall:
I´ve twisted, pulled, screwed, twisted & pulled again but although I can get it to rotate it will not come off the gear lever :brickwall:
Oh............ & I broke the top bit too :censored:
If you have broke it anyway, then out with the junior hack-saw.
Did that with my Clio.
Saw cut down each side roughly where you think the shaft is.
Worked a treat.
Cheap aluminium replacement off eBay.
Bob's your Mother's cousin....
[-] The following 1 user says Thank You to j90xxx for this post:
  • knobblywobbly
Over 25,000 of them on e-bay at present so you should be able to get one at the right price.
Really though, you need the ones with six speeds and reverse just to give you the extra edge and to totally confuse anyone else who drives your motor :lol: :lol: :lol:
it dont pull off easy
cut down several times with a junior hacksaw and it will pull off
thats what i done anyway
[-] The following 1 user says Thank You to corkgsxr for this post:
  • knobblywobbly
Yep is a right job! used a strap wrench to get mine off, was a nightmare though..... just hack it off and start again eh ? Smile Smile
[-] The following 1 user says Thank You to adam3rdcanvey for this post:
  • knobblywobbly
mine the top was broken anyway so i was replacing it with a new one. a alu one. only disadvantage is its freezing in the mornings Big GrinBig Grin
It´s off! I had to hacksaw it then get the rest off with pliers. New gear knob now fitted - her first bit of "bling".
[-] The following 1 user says Thank You to knobblywobbly for this post:
  • Andre
Glad you sorted it, picc??
This is it - It´s made by Ripspeed and was in the clearance cabinet at Halfrauds for £7.50 :thumbsup:
Thanks! Nice mod, now get a different gaitor to go with it!
Your berl is pretty tidy mate!
[-] The following 1 user says Thank You to Andre for this post:
  • sluggyson
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
