  • 13 Vote(s) - 2.46 Average
Rear axle removal, (torx head key with extended shaft?)
Hello all :wave:
My Blingo has a knackered rear axle and a friend of mine will be tackling it for me within the next month or so :woop:
My van is ply lined, and unfortunately the ply is not easily removable due to the large water tank which is fitted in the back (I'm a window cleaner).
My man has said that the removal of the axle is possible without having to remove the ply lining, however we may need a specific tool for removing a couple of nuts.
Apparently it's a Torx Head Key with an extendable shaft. What we need to know are the dimensions of this tool?
If anybody has tackled the removal/refitting of the rear axle on a MK2 Berlingo and knows which tool we need, then I would be very grateful to hear from you!!!!!!
Cheers Guys, Take Care Confusedalut:
Have a read of this, post 4. Confusedalut:
http://www.berlingoforum.co.uk/showthread.php?tid=3311
[-] The following 2 users say Thank You to Rustscrat for this post:
  • ian432, LloydyBoy
T50×75-100mm length, ½" square drive. You can get them by Draper and Koken, maybe Sealey as well.
Koken also make one that has a 5/16" (8mm) hex on the driving end and is 100mm long overall.
  • LloydyBoy
Thanks so much for that fellas!
The PDF you attached is brill as well Rustscrat. Thanks mate.
[-] The following 1 user says Thank You to LloydyBoy for this post:
  • Rustscrat
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
