  • 13 Vote(s) - 3.08 Average
Brakepads
I need to replace my front brakepads on a Mk 2 Berlingo Van, before its MOT, is it easy,whats the proceedure?
very easy it takes longer to take off the wheels
theres 2 13/14mm bolts at the back of the caliper. holding the top half of the caliper to the bottom.
it then lifts off push the pot back into the caliper, old pads slide out new ones in job done.
It is as easy as corky said. I was trying to find a thread from a while back where i listed the instructions, but havent been successful in finding it.
Mine are due shortly, I'll do a write up with pictures, it really is easy though
[-] The following 1 user says Thank You to steve valentine for this post:
  • Andre
(17-04-2011, 02:53 PM)steve valentine Wrote:  Mine are due shortly, I'll do a write up with pictures, it really is easy though
You doing the discs aswell?
Possibly, they've been on about two years and for what they cost I may well replace them, rear pads should be due a change as well.
why replace disks just cos they`v been on for 2 years?
you should get over hundred thousand miles out of a set of disks
(17-04-2011, 04:20 PM)corkgsxr Wrote:  why replace disks just cos they`v been on for 2 years?
The discs on mine had to be changed at 36,000
because they feel a bit juddery on braking hard so may be slightly warped, and because I want to.
ah how much are std disks.
ebc do slotted disks for berlingos
Mileage
Today 04:33 PM
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
