  • 13 Vote(s) - 2.92 Average
new cd player problem
fitting a sony cd player at the mo everything connects straight in but because the berlingo has no acc position on the keys the radio never turns off?
what do ya do with the live and switched live to make it work normal
http://www.berlingoforum.co.uk/showthread.php?tid=138
This might help you.
But i thought aftermarket stereos had a steering wire (i think its called?, blue one) that signals when the ignition is either on or off.
right way i figure it the yellow wires stay connected. there the permanent power, i need to wire the red switched live to something that only comes on when the ignition is turned on.
so what do i wire it to thats not essential like the fuel pump
right problem solved
pop off the facia that covers the electric windows and heated windows and stuff
take out the drivers side electric window button connect the switched live wire to the number 3 connection.
now when you turn on your ignition radio comes on when you turn it off or go to eco mode radio turns off
right doing it that was leads to the small screen on the dash freezing and turns out the Citroen permanent live isnt permanent, it cuts power when the doors are locked so i was losing all presets
so i wire the permanent live direct to the battery. went out the plastic blank for if its a left hand drive. all is now working as it should :thumbsup:
(18-04-2011, 06:46 PM)corkgsxr Wrote:  so i wire the permanent live direct to the battery. went out the plastic blank for if its a left hand drive. all is now working as it should :thumbsup:
nice one corkgsxr! was gonna suggest the blanking plate method.... but you got there first, Have got my airhorns running through that to the seperate push switch in dash.
Did you fit an inline fuse between battery and your stereo, might not be a bad idea if you're planning to run amps/subs etc??
right doffo works perfect tryed everything tonight.
no inline fuse at the mo cos i dont have one, but i will put one in just to be safe.
if i have bobs ill put a amp in, the HU is set up for it
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
